Newbie: Problem with Setup- Please help
Discussion in 'TVs' started by JLC, Jan 7, 2005.
  1. JLC
    JLC
    Hi there, I wonder if you can help. I bought a new tv for Xmas and have connected the following equipment.
    Philips 24pw6518:- Two Scarts:- One RGB, One Comp/Video
    Panasonic DVD Player:- One Scart
    Panasonic Set Top Box TUCT20 :- One Scart
    Hitachi VCR :- Two Scarts
    I connected the DVD Player straight into the RGB scart of the TV.
    I connected the Set top Box into the Video Recorder, then the Video recorder into the other TV Scart socket.
    Have I connected this all in the best possible way??????
    It appears to work fine for the DVD Player and the Video. There is however some problem with the Set Top Box. I have noticed there is a horizontal line that works its way up the picture. Its faint, but once you start noticing it, it is a bit annoying! Takes about a second to go all the way up. Looks as though the picture is scanning or something.
    Any help on why its doing this, any solutions and also is it better to connect another way would be really welcome. Many Thanks for your anticpated help.
    JLC
  2. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    sounds right to me :)
