Hey. I'm doing some DIY in a month and, eventually, we'll be looking to get a projector in the lounge. This will likely be towards the end of this year, so quite a way off.
As I'm doing a suspended ceiling over part of the new lounge, I think now would be a good time to get the screen in place. I'm looking at the PC106MET 106" CinemaScope 2:35, which has a viewable width of 248cm. I will be buying in the next day or two. Before doing so though, I'd like to confirm it would work in my room given to get the required throw length, I'd have to mount the screen off centre.
This is what I'm looking at doing:
The actual projector will depend on several things, but given my requirements for a reasonable throw and lense shift, I've worked it out on the basis of an Epson EH-TW2900 / 3500 or a Panny AE3000/4000.
I've planned a 15cm gap behind the projector, and 10cm on the side (based on the 30cm depth of the Panny, but the increased throw of the deeper Epson counters that, so to all intents and purposes both should be very similar at this range).
With a throw of 355cm, I can get a 248cm width without maxing out wide angle (which I'm trying to avoid). However, I'll be offset horizontally by 36cm. I believe I'm OK doing this, as the Panny for example can have a 40% offset which in my case would be 99cm. I've gone through the maths several times but wanted to check with the experts here that everything would be fine.
I've no idea of the vertical offset at this time as I don't know the drop of the screen, but I can be pretty flexible vertically so it shouldn't be so much to significantly impair the horizontal shift.
Thanks so much for the time, if I'm doing anything stupid here please let me know
Matt
Matt
