Newbie - Panny E55 format
Discussion in 'Blu-ray & DVD Players & Recorders' started by Shall, Dec 6, 2004.
  1. Shall
    Shall
    Hi guys - an easy one to start the week.
    Basic requirement - to replace VCR's with DVD recorder + players.
    Purchased, after scouring specialist media, Panny E55, and 2 x Tosh SD240SE's. Simply wanted the ability to play recorded DVD's in other rooms on budget "acceptable" players - without the need to archive, so re-writable media essential, at present.
    Looks like big mistake. Will the E55 only record onto DVDRAM, which I am told the Tosh's will not play? Or can the E55 record onto other RW media, which they can play? Haven't bought any blanks yet, until I sort this out.
    If I get a negative, any suggestions for budget players which can play DVDRAM that I can swap the Tosh's for, as I would like to keep the E55? I assume only made by Panny?
  2. HMHB
    HMHB
    Nov 11, 2001
    25,514
    Nottinghamshire
    +3,851
    Yes, the E55 will only write to RAM rewritable media. I had the E85 in one room and was looking for a cheap player that would play RAM in the other room - I ended up buying an E55 for the other room as they are now under £200. I'm not sure what the cheapest RAM player is to be honest though.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Whether a player will read a RW disk is usually a lottery anyway :)
  4. mentsugi
    mentsugi
    Oct 2, 2002
    385
    +24
    The latest Panny DVD players all play DVD-RAM and can be had for about £70.
  5. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    Very few players will play RAM.... take a look at http://www.videohelp.com
    You can search on players with various criteria, including RAM.
    One that apparently does is the Pacific-DVD1002. These were available from Asda very cheap... not sure if this is still the current model, but other Pacific players may do the same.
    Mark
  6. imichael
    imichael
    Nov 5, 2004
    209
    16
    West Sussex
    I don't think the e55 is specced to record on dvd-rw, just dvd-r and RAM. DVD-Rs' are very cheap now - just over a tenner for 20-25 disks depending on which online retailer has a deal going.
    Your toshibas' should be fine with dvd-r.
  7. Shall
    Shall
    Thanks guys. So what we're saying is, if she wants to see last night's Corrie it'll cost her about 50p, or chop the Tosh's in for a Panny player, or gamble with anything that plays DVDRAM, quality unknown. Trouble is, the Tosh's got very good quality ratings for budget players.
  8. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You can also get a DVD player for PC's that reads DVD-RAM for about £14 from EBuyer
  9. Shall
    Shall
    Thanks, everyone. Have decided to return the Toshibas, and go the Panasonic route with an S27 or S47 - unless anyone says don't!
  10. imichael
    imichael
    Nov 5, 2004
    209
    16
    West Sussex
    If your wife is going to watch corrie using the e55, then you can get upto 8 hours on a -r disc, if you don't 'finalise' it until it is full. Until the disc is finalised it will only play on the E55.
    Ian
