NEWBIE: Nuvi 300 POI question
S
Smoothas
Hello,:hiya:
I resently got myself a Nuvi 300 and I have been trying to load up some POI using Garmins own POILoader software.
I go thought all the steps OK, but when it trys to copy the POIs over, It tells me that "The card is not ready".
My Unit does not have a SD card it in as the information on the Garmin websites says that you can load POIs either on the unit itself or a SD card.
My question is, how do I load POIs onto the Nuvi itself ( there enought room as I have moved all the redundant Voices, Car images etc over onto my PC ).
Thanks in Advance :smashin:
S
steve_d
Bit new to this myself, but when I update the POI's on my 360, I have to chose drive 'E' (nuvi) although there is also another option, 'F', (card reader) even though I don't have a card in it. Are you chosing the right drive??
S
Smoothas
That did it. DUHHH, Feel so stupid for not noticing that. Thanks Steve d.
