Newbie needs some help with a Pronto
Discussion in 'Home Cinema Control & Remote Controls' started by steven_9709, Jan 4, 2002.
  1. steven_9709
    steven_9709
    Jan 4, 2002
    786
    46
    Shortstown - with the Snails
    +170
    Hi everyone
    Thinking about buying a Pronto to replace my numerous remotes....can anybody tell me the difference between the Pronto and the SBC-RU890?
    Also, where's the best place you've found to buy one from? Richer Sounds are doing them for £145.95 + £3 P&P, but this doesn't include the docking station. Is it worth getting?
    Thanks in advance:D
  2. mjn
    mjn
    May 24, 2001
    23,211
    Herts, England
    +11,442
    If you buy pronto, the dosking station is bought separate, and you have to download the prontoedit software. If you buy the marantz version, you get everything you need in the box.
    for all info, goto www.remotecentral.com they have reviews and resources for all remotes.
