Newbie needs help with SP4805
Discussion in 'Projectors, Screens & Video Processors' started by gnc123, Mar 8, 2005.
  1. gnc123
    gnc123
    I have recently bought a screenplay 4805 and have been hugely impressed with the quality of DVD playback etc. I now want to play cable TV through the system.
    The problem I have is that the projector is in a separate room from the telewest box. There is a socket for a TV ariel in the room with the pj and if I plug a portable TV into it I can see whatever channel the cable box is switched to. How can I get this signal onto the pj with the best possible picture quality? (I have a denon dht500 receiver)
    any thoughts?
  2. ismangil
    ismangil
    Nov 30, 2004
    Sheffield
    I also use Telewest with 4805, I'm afraid RF modulation is the lowest quality you can get. I tried using composite (the single usually yellow phono cable) which is supposed to be better than RF but the image was still awful, there were wavy lines etc.
    I ended up buying an RGB to S-Video converter and used a 10m S-Video cable to the PJ, and image quality is now very high quality. If you can afford it, there is even RGB to Component converter...
    You might consider getting a second digibox just for the projector...
