Newbie Needs Help Choosing DSLR
Discussion in 'Photography Forums' started by pg325, Jun 6, 2008.
  1. pg325
    pg325
    Apr 21, 2007
    115
    +7
    I'm thinking of purchasing a DSLR, have a budget of around £300 ish.
    I want mainly to take macro shots of my corals and fish in my marine tank, but also take along to the Silverstone GP next month.
    As a beginner I really need some help with the mountains of choice and where to buy.
    Many thanks
    PG.
  2. Sigismund
    Sigismund
    Jan 14, 2003
    5,535
    London
    +102
    Hi there.
    Probably best bang for your buck at the moment is the Sony Alpha 200 with 18-70mm kit lens from Dixons - £275.04 and even less using promo code AW5, less again if you go through Quidco and possibly even less if you use an Egg card! You could then add the 70-300mm Sigma macro lens for not much more...
    The Olympus E-510 is also good value - and will probably become even better value soon with the upcoming release of the E-520. Olympus kit lenses offer excellent sharpness, and their 35mm macro lens has a very good reputation. :thumbsup:
  3. TarMoo
    TarMoo
    Feb 16, 2005
    1,452
    Kent
    +298
    A good macro lens like the Tamron 90 will set you back a couple of hundred, so you best stick with the kit lens that comes with a budget SLR. Apart from the Sony there the Nikon D40 is a popular choice for a budget DSLR.
    Long term, if you plan to buy a lot of lenses and other extras then the best selection are these brands --- Canon, Nikon and then Sony. Third party lenses from Sigma, Tamron etc are usually available for these three mounts.
    Best to have a try of the alternatives. If you buy online at Jessops then you can pick up in store. See www.camerapricebuster.co.uk
  4. SatDude
    SatDude
    Nov 29, 2006
    1,028
    +39
    Quick question Mark, for a beginner would you recomend a Sony Alpha 200 or Nikon D40.
    I've seen the D40 and looks great but the Sony Alpha 200 seems to have better specs...
  5. Sigismund
    Sigismund
    Jan 14, 2003
    5,535
    London
    +102
    Hi there. There are so many variables in buying into the dslr world that I think it really comes down to personal preferance. I would say that unless you're a complete technophobe either camera will be fine for a beginner, especially after reading something like Understanding Exposure by Bryan Peterson. :) Of course, if either camera feels wrong in your hands then it's not the one for you.
    Also, it's really about buying into a system - some people like the Nikon brand, others prefer Canon. Olympus does everything I need, and having read many, many reviews I believe they offer the best kit lenses. Having said that, I'm sure that if I owned the Canon 40D or Nikon D300 I would be perfectly happy... although my bank balance would make me feel less than delerious - I've ended up with an E-510, 14-42mm, 40-150mm, 50mm macro lens, EX-25 extension tube and an FL-50 flash for less than the cost of a Nikon D300. :)
    One final word from me! I think it's all to easy to buy into a system and, for one reason or another, end up feeling that the grass may be greener elsewhere. That's fine, but I think it's important to learn about the art and craft of photography using whatever camera you own before trading up... unless, of course, money is not a hinderance!
  6. Pirate!!
    Pirate!!
    Mar 16, 2005
    7,736
    Liverpool
    +1,217
  7. Gow87
    Gow87
    Dec 18, 2007
    244
    +23
  8. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
    Aww bless them..El Reg is reviewing cameras :rotfl: I noticed they reviewed the 400D last week...what's next a scoop on the Olympus OM10?
    Don't give up the day job guys!
    I wasn't too impressed by this comment for a start
    "It's also a shame that there is no image stabilisation system and the best Canon can suggest is using a tripod."
    err guys...IS lenses maybe?...Canon EF-S 18-55mm f3.5-5.6 IS for £109 :mad:
    I must admit though I DID read a very glowing review of the A200 in one of the digital photography mags a couple of weeks back, but I still wouldn't trust reviews from the IT equivalent of the The Sun!
    Quick PS
    I just read the dpreview article on the A350...not exactly glowing!
    http://www.dpreview.com/reviews/sonydslra350/page31.asp
