Newbie needs advice on buying camera
Discussion in 'Photography Forums' started by chromeman, Jun 17, 2004.
  1. chromeman
    chromeman
    Hi there,
    I am currently looking for a digital camera. I would like it to be small and compact (so it'll fit in a jeans pocket). I need this because I am planning to take it to live gigs a lot and don't want to have to hold onto it for the whole gig.
    I'd like the resolution to be at least 3.0mp and would also like it to record movies.
    I was looking at the Fuji F420. Good idea?
    Any comments/suggestions would be gratefully recieved!
    Thanks for reading! :smashin:
  2. SanPedro
    SanPedro
    Jan 11, 2001
    4,539
    +520
  3. chromeman
    chromeman
    Thanks for the reply.
    Do both of them record video for an unlimited amount of time (i.e. as much as can fit on a memory card) or do they only record for 30ses or something?
    Cheers!
  4. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Most dont take unlimted film, most are round 3 mins and under though you can just start again after then edit with softwear. Another thing you'll have to think about if its using any small digi cam at gigs is the darkness. The optio S4 is a fine lil cameara you're going to want to be right up at stage to capture picture with the flash that comes with such small cameras.
    go to www.pricerunner.com for the best price on the pentax optio s4
  5. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    I have the optio s, which I chose instead of the casio exilm as it was smaller and more pocketable, and also has a zoom.
    Its a great camera for taking anywhere, and being able to have with you at all times.
    It takes 30 second movie clips with sound, with about 5-8 seconds to record to the card between captures.
    Only annoying bit is the shutter lag, which could lead to some missed shots. Its OK if you remember to pre-focus with half press of the shutter release button though. The casio exilm has the fastest startup and shutter release time though, as it has a fixed focus and no zoom optics
  6. SanPedro
    SanPedro
    Jan 11, 2001
    4,539
    +520
    Just been flicking through a PC mag and noticed the New Minolta Dimage Xg. This looks to be a very compact 3Mp camera and is only £148 compared to the Optio S4i at £244 in the same publication.
    It looks ideal for the back of pocket portability you were after.
    But for double the price the new Sony DSC-T1 at £299 looks very slim indeed and comes in with a 5Mp image.
    CL
  7. chromeman
    chromeman
    Where is it £148?? The cheapest I've found it is £159.99. Its funny you should mention it, I think I'm set on that one. Was thinking of going to Jessop's later. They said they would price match the amazon price too!
  8. SanPedro
    SanPedro
    Jan 11, 2001
    4,539
    +520
    Ooops. Just double checked the magazine and the figures are ex VAT :blush:. Sorry about that.
    Actual price was £175 inc VAT.
    I only ever look at ex. VAT figures as this sort of gear gets put through my business.
    CL
  9. chromeman
    chromeman
    hehe no worries! Thought I'd found a bargain then!
    Thanks for the info!
  10. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    This months PCPro magazine (Aug 2004 !) has a review of 14 of the smallest cameras currently available
    The Exilim EX-S20, Optio S4 and Ixus i, get good reviews
  11. FoxyMulder
    FoxyMulder
  12. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
