newbie need help finding a system
Discussion in 'AV Receivers & Amplifiers' started by thesnowman, Jan 15, 2004.
  1. thesnowman
    thesnowman
    Nov 14, 2003
    271
    +8
    I'm pretty new to all this home cinema stuff and was wondering wheather anyone could help me find a decent av receiver for £200
    *my main use for the system will be movies and sky tv
    *I will be using it at least 6-7 hours a day, so please warn me to avoid any system that are prone to over heat
    *my living room is fairly small so I dont really need a system that is built for a stadium
  2. stevo29
    stevo29
    Dec 3, 2003
    27
    3
    Devon
    snowman
    have been using a pioneer vsx-d511 for about 5mths, very happy with it;the amp has dolby prologic, prologic 2,dolby digital, dts, & virtual suround back & other dsp modes plus stereo, more than enough really; we use the amp in our small/medium sized lounge, have had no problems with overheating,(advisable not to place another component on top of this amp for ventilation purposes so could be a problem if you lack space in your t.v unit?
    i originally purchased a one boxed integrated dvd/receiver at the start of 2003 but found connectivity lacking so switched to the vsx-d511; the newer model d512 has been reduced to £139.99 +£7.99at empire direct, a bargain to be had..
    the link http://www.empiredirect.co.uk/productdetails/index.asp?modelcode=PIO-VSXD512S&affiliateid=
    also check out the a/v receivers at richersounds http://www.richersounds.com/index.php?f=itemlist.php&c=1101
    regards
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Also Yamaha HTR5630 and denon 1603 if you dont mind black, have a search as there are loads of threads on this price range.
