Newbie - My first attempted setup
Discussion in 'AV Receivers & Amplifiers' started by KP2000, Jul 28, 2004.
  1. KP2000
    KP2000
    Hi all, Appologies if this is in the wrong forum and appologies if it is the same old question asked again...
    I am looking at buying my first home cinema setup but have a very small budget at the moment. I have been looking on RicherSounds and seen the following kit and just wanted any advice. Ideally I would like to go the seperates route but it seems to be a bit of a minefield...
    Sony STRDE495 - £99.95
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=301893
    Eltax HT2 Rear Speakers - £29.95
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=301987
    Mission M71i Fronts - £59.95
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=301131
    Mission M7ci Centre - £49.95
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=301622
    The next question is, I have managed to acquire a set of Pioneer Speakers and Subwoofer would they be ok on the amp until I buy the main speakers.
    The room size is 14ft x 14ft (roughly)
    My budget will only be £300 MAX over a couple of months this has to include speakers also, I dont want to go the second hand route either, oh and to top it all off it HAS to be Wife Friendly.
    I hope I have put the right information in there and I appreciate any help.
    p.s. I already own the DVD Player - Pioneer DV-454
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    What TV and you can get more WAF but means spending a bit more, what are pioneer speakers,
  3. KP2000
    KP2000
    Sorry the speakers are Pioneer SSP40 and the sub is S-w40s
    TV is Hitachi 28" Flat Tube Nothing spectacular
    need to move one step at a time with the wife so screen is the next upgrade.
    What is WAF?
    Sorry if that was a stupid question...
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Wife Accepatance Factor :smashin:
    I think you are selling yourself short ignoring the second hand market especially for a better amp than the low range Sony
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Pio speakers ok with basic amp, look at pioneer VCXS 100 and 300 range, also make sure speakers are magnetically shielded.
