Newbie, Low down on Yammy AX750 SE
Discussion in 'AV Receivers & Amplifiers' started by jimmyfixit, Oct 13, 2004.
  1. jimmyfixit
    jimmyfixit
    :lease: As by the title of this. Have been told to get this amp by a friend, as im doing a home cinema. What is the features, spec etc. Thinking of using it in a set up with panny PW6, Screenplay 4805, Mordaunt short avant 5.1, tosh 220 dvd, sky, xbox, ps2, tv. what do you think? Any probs or conflictions?
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  3. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Also there is a review of it at the top of the page! Read that is very informative:D
  4. TheeNoMaD
    TheeNoMaD
    What are the presence speaker terminals used four, i hear rumours you can rig up nine!!! speakers to the yamaha. Are the rumours true?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    second room stereo?
  6. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Yup you can rig up 9 speakers if you have the room but you cant use more than 7 + sub at one time unless you have the rz9
  7. TheeNoMaD
    TheeNoMaD
    Okay cheers dude. I think come pay day it wil be a shiney new Yamaha 750se then and the pioneer 575.
  8. jimmyfixit
    jimmyfixit
    :oops: I did search & read the info on this amp, BUT being a bit of a newbie to this, some of the jargon and terms is jargon to me (but im starting to pick it up), thats why i asked is it worth getting for what i want to connect to it? Sorry for asking again (Dfour)
  9. ktng
    ktng
    May 9, 2004
    174
    16
    UK
    There is no problem with asking advice and/or explanation of certain features, BUT you did originally ask for details of features and spec; so I think it was quite correct that the search facility was pointed out.
    As far as the other part of your query - I can't see any problems or conflicts. The 750 is a very capable AV amplifier and I doubt that you will be disappointed, although it is difficult to be certain of that with the limited information you have given.
  10. Stimpy
    Stimpy
    The only thing to really worry about is the fact that this amp only has two component inputs, so you need to look at what you watch the most and which sources should have the best quality connections.
    My own personal preferences would be
    DVD -->Component connection in
    Sky -->RGB to component converter (loads of threads) --> Component in
    PS2 -->S-vid in -->Component upconversion in amp
    XBOX-->S-vid in -->Component upconversion in amp
    VCR -->Composite in -->Component upconversion in amp
    Component out -->Plasma
    This amp is also 7.1 capable so you may want to get some more speakers for the rears.
  11. jimmyfixit
    jimmyfixit
    thanks for all your help peps, what a great forum, once again many thanks to all, keep up the good work :thumbsup:
  12. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  13. jimmyfixit
    jimmyfixit
    Dfour, you must be a mind reader, these are the speakers that i have got in mind, but the whole 5.1 set up i.e Front MS914 (poss MS 906 if budgets allows), Centre MS 905c, Surrounds MS 903, Sub 309 all hooked up to a yammy 750 amp, what do you think, are these well matched/sounding?
  14. TheeNoMaD
    TheeNoMaD
    cant see anything wrong with that at all though from what i have read hooking sky up through component on your amp is bad and you will probably get a better picture through normal rgb (if you use a decent cable) though i have no first hand experiance of this i am just going on what i have read. Though i noticed a significant leap in picture qualit through sky by just using a better scart cable. The rgb only squart from super-fi is like 25 quid and its very good (ie what i am currently using )
  15. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    ms304 for rear centre as its easily wall mountable imo
