Newbie Here!!
L
Lex01
Greetings people!
Will very much appreciate a little help or advice...
I have recently bought the Jamo DVR50 (with A305 speakers) and am just wondering about the quality of connections. At current I'm using the bog-standard scart supplied to connect it to my TV (Sony 32FQ80 - has 2 RGB scart, 2 normal scart, S-video, phono). I am also using the speaker cables supplied with the Jamo system to connect the surround speakers.
There, enough of that...!
Just wanted to know if the cable supplied is any good and if I should invest in some new ones, if so, which one? Not too pricey I hope. Also, Is it worth buying a good quality RGB scart as the picture quality seems to be pretty good (my opinion).
Last note, is there no way of getting DD5.1 out from my digital NTL box?
Many many thanks in advance...
L
Lex01
Well, I took the plunge and went off and bought some cables to test out:
I bought a £2.49/m QED speaker cable from Richer Sounds, a Cambridge RGB scart (£19.99) and a normal Cambridge scart (£9.99).
Firstly, I didn't notice any difference when swapping the above scarts for the one given in the Jamo system and NTL box. What should I be looking out for? The quality of the picture seems to be good regardless of which scart I use.
Secondly, I replaced the cable provided by Jamo to one of the rear speakers. The QED cable was a lot thicker so the end that went into the DVR50 hat to be trimmed so as to get the wire into the socket. The end that went into the speaker seemed ok and needed no trimming.
The sound seemed to be slightly louder (with the QED cable) than compared to the standard cable provided by Jamo. It probably was my brain wanting to think the QED was better because I thought music sounded clearer, but there really wasn't much in it. One thing however, using the QED produced a high frequency noise, which listening from close to the speaker could be annoying.
Conclusion: well, being such a novice at this I really couldn't tell the difference!
hornydragon
#Just check that ntl is set to RGB. (RS isnt the best place for buying cables TBH) HF noise sounds strange double check that no wires are touching something they shouldn't.
L
Lex01
Thanks,
Who/where do you recommend if not Richer Sounds?
The NTL box it outputed to RGB. Will look into that speaker cable again.
hornydragon
well depneds on the cables/ but for standard scarts etc tlc direct are good! speaker cables where ever has best price, RS cables arent that good for the money!
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
