Thunderbird_010
Ive decided that I want to take photography up as a hobby and although the question has been asked probably a 1000 times wanted some advice on which camera.
Budget wise im looking around the £400-£450 mark, use wise want something that is easy to use to start off with and thet I can add longer range lenses to in the future that will still be available but not be too expensive. HD video would be good but not necessity as already have a hd camcorder.
Picture wise looking to do probably landscapes and use it to take pictures of family etc. Its an absolute minefield and my head is spinning with looking at different reviews ive had a look at some reviews and the ones ive seen for my budget are Panasonic Lumix GF1, Canon 1000D Nikon 3000 and Sony A290. Im sure there are many more and appreciate your advice and thoughts.
