After lots of listening at my local superfi, I have now purchased the denon df102 and b&w600 speakers (was planning on cheaper speakers but in my opinion the sound didn't compare)
I now need some speaker cable:
It needs to be white preferably so it doesn't stand out and able to fit between the skirting board and carpet.
I need lengths of 7.5m and 3.5m
I'm not loking to spend too much at first.
I probably won't be able to test any cable before I buy.
Can I attach the cables just with the bare wire ends or are terminator plugs advisable?
