Quantcast
Question Newbie Help with Projector Mounting
SamSungTunes
Hello,
Little lost with this 'universal' mount i have purchased. How on earth do i mount it to this HD65 projector?
Images are included below, i am baffled?
jfinnie
You only need 3 of the "legs" it seems on the spider, to attach to these points on the projector using screws (hopefully some supplied with the mount?). Make sure they're not too long for the projector base - can cause damage if they're too long, or bottom out in the threaded inserts. If you loosen of the screws for the spider legs you can spin them around as required.
See similar mount attached to a PJ here:
