newbie , help with connections
Discussion in 'Projectors, Screens & Video Processors' started by rob virgo, Nov 27, 2004.
  1. rob virgo
    rob virgo
    Nov 27, 2004
    218
    16
    hi ,
    please help a newbie to the scene.
    i have a sony1271 qm projector and a component out pioneer dvd.i cant get the picture right on the screen.
    i have used the single video out for the mo to get a picture and was delighted with the result.i know it will be much better with some good advice re proper conections.
    sony doesnt take a component input so im told so i have ordered an s video cable to link them.
    i have mission speakers with sony dd/dts processer.
    ideas please :thumbsup:
    rob
  2. Flimber
    Flimber
    Sep 22, 2002
    13,681
    Yorkshire
    +4,477
    Does that Sony have RGB in via either a Scart or BNC's ?
    Mike.
  3. rob virgo
    rob virgo
    Nov 27, 2004
    218
    16
    mike ,
    its got five bnc inputs.some kind of rgb with two extras.
    ran the component to it matchin colours and all i got was a red(i think) picture.
    component/scart and s video out from dvd
    cheers :smashin:
    rob
  4. mi_july
    mi_july
    i do believe that those two extra's are the H and V (horizontal and Vertical) sync. someone correct me if I'm wrong.
  5. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    It is RGBHV. I used to have a couple of old Sony CRT PJ's which I ran via Scart and Keene Syncblaster cables from both DVD and Sky sources and I was very chuffed at the picture at the time.
    Go to the FAQ page at www.crtprojectors.co.uk - Its a bit like 'early Sony CRT 101' and will answer a lot of your questions. Henry and James are helpful blokes too!
    The syncblaster isn't cheap but linked to the wonderful £10 RGB Scart switcher from Argos handled all my switching with no fuss. Keene sell them via a dedicated website.
    There are other options too. You can use the VGA (15 pin computer monitor port) for scalers & HTPC. This'll give you a better picture but may give you audio delay problems.
  6. rob virgo
    rob virgo
    Nov 27, 2004
    218
    16
    cheers for the help lads.looking at a DVD-2910 from denon now.it has a scaler built in.have to check if its compatable
    cheers
    rob
