Newbie - help to choose a player
Discussion in 'Headphones, Earphones & Portable Music' started by lisag, Apr 10, 2005.
  1. lisag
    lisag
    Jul 14, 2004
    5,993
    Essex
    +398
    I want to buy a MP3 player/USB2 flash drive with 512mb memory... just been searching online and the market is totally flooded with them.
    Can anyone recommend any players to me... I just want it to work properly, sound good and look cool (of course) :cool:
    Thanks very much
    :lease:
    lisa
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    iPod shuffle? Easy to use, and easily syncs with iTunes and changes songs/playlist. But it doesn't have a screen.
    Or the Sony Sony NW-E99 Network Walkman. This has a screen and a longer battery life.
    Or check out the MPMAN range.
  3. lisag
    lisag
    Jul 14, 2004
    5,993
    Essex
    +398
    Hi, thanks a lot for the response,
    I am a bit anti-apple, or rather anti-itunes so was going to avoid anything ipod related, I would prefer to just drag and drop files in windows.
    I will have a look at the sony one you recommend, I have found a Creative Muvo V200 which has a screen, fm radio and looks cool - anyone heard of these?
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    If you want to drag and drop, I don't think the Sony will be suitable.
    I'm not sure but I think that Creatives do support drag and drop, so that might be suitable!
  5. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,465
    +6,239
    Why anti-itunes? I'm no apple fan-boy (I have bought Sony all my life) But I can appreciate how simple it is to use Itunes. Drag & drop would be great on every player but its not like its hard to use Itunes. Now if only Sony sorted out SonicStage............If u just want Drag + Drop then u have already limited your choice. Afterall its due 2 DRM we have music management programs wit players.
  6. lisag
    lisag
    Jul 14, 2004
    5,993
    Essex
    +398
    Hi, yes, I understand that i-tunes has its advantages, I just get the hump with being forced to use software for no apparent reason, when drag and drop should do the same job. Also I want to listen to recorded radio shows / comedies / etc, not just tunes...and I don't want to be forced to organise my mp3's into libraries.........I know - I am fussy and grumpy :rolleyes:
  7. mcav
    mcav
    Nov 11, 2004
    456
    +58
    Having listened to A MuVo, I can safely recommend one.
    User interface is fine, battery life excellent and playback quality excellent - especially when you set the eq right.
  8. lisag
    lisag
    Jul 14, 2004
    5,993
    Essex
    +398
    Thanks everyone for your help - will go for the Muvo :smashin:
