Newbie Help: Subwoofer cable
Discussion in 'Subwoofers' started by Ponty, Jun 23, 2005.
  1. Ponty
    Ponty
    Feb 15, 2005
    68
    Haven't made a decision on a specific sub yet, but am at the point where I am putting cables in the wall etc for plasma, YSP1 install.
    What cable do I need? Standard speaker cable, phono lead (are they all the same?).
    Haven't had a sub before, so advice please? Advice on a small footprint sub suitable for the YSP1 would be appreciated
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    You want a mono interconnect. This will consist of a piece of coaxial cable with an RCA plug at either end - if you go to any website and look for "Subwoofer Cable" then you'll get the idea very quickly. Mark Grant does a very good one in the forum Power Buy section.
    You don't provide a price range but depending on your budget you should consider looking at the BK XLS200, Velodyne SPL or DD series and perhaps the Sunfire models as a starter for 10. :)
