Newbie help required
Discussion in 'Cables & Switches' started by sondeck53, Dec 10, 2004.
  1. sondeck53
    sondeck53
    :confused: can anyone tell me best way to hook up cabling to and from:
    TV, DVD recorder, Free to air sat, Sky sat and receiver amp so I can record
    from each satellite.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    which DVD recorder you may want to consider a holden or Quintro Scart controller (have a search here) or use a JS MSC box to feed both into the DVDR depends on the quality you need and what coonections are on both boxes
