Newbie help required - pc to hifi advice
Discussion in 'Cables & Switches' started by Westender, Nov 23, 2004.
  1. Westender
    Westender
    Jun 14, 2004
    56
    London, UK
    +10
    I'd like to be able to play mp3's on my pc throught my hifi rather than through the pc speakers and subwoofer. Is this possible? If so - what do I need? Grateful for any advice.
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    Depends on your SCs audio outputs & the kit you have in your hifi
    2 main ways from soundcard for instance :
    Digitally via a toslink optical output or a RCA SPDIF coaxial output these are hard cabled ways (ie that require a cable link), or via Wifi Airtunes Express and such like from a PC to a Squeezebox and then towards an amplifer. This then fed towards a hifi or stereo DAC (Digital to Anlg Convertor) which then sends a signal towards your amplifer (just like a CD Player).
    Analogue again depending on the SC you use the anlg output size vary, most cheap SCs have a 3.5mm Minijack (just like a headphone jack) all you require is a 3.5mm Minijack To 2 RCA cable, these are quite cheap. The other anlh way is exactly like the anlg outputs on a CDP, ie RCA phono outputs.
    Do a search over on the Hifi forum to see all the threads concerning the points above.
  3. Westender
    Westender
    Jun 14, 2004
    56
    London, UK
    +10
    Only got a crappy sound card with a 3.5 mm minijack which is already connected to the PC speakers. Is there such thing as minijack adpaptor which would enable me to plug both the pc speakers and subwoofer and my hifi into the same 3.5mm jack on my pc?
