Newbie, help! - Panasonic TUPTA600 Extension Cable!
Discussion in 'Panasonic TVs Forum' started by MIOM, Mar 21, 2005.
  1. MIOM
    MIOM
    Hi there, I wonder if any body can help me!
    I recently bought a 42PW7 from AV-Sales and am using the media box for convenience, plus the picture quality through it seems excellent.
    Only one slight problem, the cable supplied to connect the box to the screen is 3m long and I need 5m. I know you can buy a 15m cable for about £100, but fact is I don't want an additional 10m of cable clogging up my tidy space!
    I think the connections on the box are HD26 type connections and was thinking of having a 2m extension cable made for it from the US. Does anybody know anything about this cable? Or has anybody else had this problem?
    Any help much appreciated!!!!!!!
  2. MIOM
    MIOM
    Hi guys
    No longer an issue, have found a solution much cheaper than the 15m cable offered by Panasonic!
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    care to share?
  4. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    He moved the screen closer! :eek:
  5. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
