radicalrajat
Hi Folks,
I am planning to buy a home theatre system and could use some help. I have the following sources that I need to hook up with the Home Theatre:
1. Linksys EVA9150
2. PS3
3. LCD
4. dvd player
I had initially looked at Bose V30 & 38 as options, but am having second thoughts after going through some of the forums and would like to research as am sure equal or better options exist. My budget is around USD 4500 which I believe should be pretty good for getting a competitive system. The room size is around 25 ft X 30ft and I would prefer satellite/bookshelf speakers.
Would appreciate some sound bytes from the experts on this forum on possible options I could consider. I am open for both, all-in-one as well as independently sourced components.
Regards,
1. Linksys EVA9150
2. PS3
3. LCD
4. dvd player
Regards,
