Newbie: DVDO iScan HD or DVI DVD?
Discussion in 'Projectors, Screens & Video Processors' started by SMabille, Jan 20, 2004.
  1. SMabille
    I have a stupid newbie question:
    I'm buying a Sanyo Z2 and replacing my DVD player.
    And I need advice, which config should I get:
    1) DVDO iScan HD and a basic player (interlaced PAL/NTSC)
    2) DVDO iScan HD and a progressive scan DVD (480p,576p)? and what dvantage will it give as opposed to the first solution
    3) A DVI enabled DVD? If yes I suspect a non HDPC one that resize the pic to the projector native resolution.
    4) A non HDPC enable DVD with DVI output and let a iScan resize the picture (and get the iScan for the other sources as well)?
    PS: In case of DVI DVD: Do you know any good non HDPC (as it's needed for resizing either onboard or by the iScan) NTSC and PAL progressive and multiregion player?
