Newbie: DIY Screen
Discussion in 'Home Cinema Building DIY' started by cosmic023, Sep 24, 2003.
  1. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +88
    Hi All,
    My new screen design (Not yet built) is 72" x 54" frame size with 68"x52" viewable screen (4:3 ratio) (2" black velvet border) using Dazian Celtic Coated Cloth as the projection material.
    What i need to know is how do you work out the diagonal size of the screen ??
    I'm sure there is an easy method ??
    Sorry for a such simple question......
    Cosmic023
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Simply use Pythagoras' theorem....
    68^2 + 52^2 = 83.24^2
    So it would be 83.24" diagonally.
    Cheers, Lee
    BTW should it not be 68 x 51 if it's a 4:3 format screen ?
  3. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +88
    Hi Loonatic,
    Cheers for the formula, i'll keep that one written down for reference.
    Yeah, i did notice my mistake about the screen size after posting it !! DOH !!
    Many Thanks
    Cosmic023
