Newbie deciding between Sony Str-DB790 or Cambridge Audio Azur 540R
Discussion in 'AV Receivers & Amplifiers' started by Stroganoff, Dec 26, 2006.
Tags:
  1. Stroganoff
    Stroganoff
    Hi there, just deciding on my first system to mach my Pioneer 565-DVD. I have about £600 to spend on an Amp and a pair of floorstandings. I did a research and some listening tests however, I am not able to choose between theese 2. I would like some opinions on the sound, features, and reliability.
    Additionally, I'm thinking about a pair of Wharfedale diamong 8.4's as a start for my budget system, what do you think??
  2. Strobe
    Strobe
    Aug 29, 2003
    2,881
    Southampton
    +181
    I have the 540R for a basic bedroom set-up and I am very pleased with it but the 540R v2 is better if you can stretch the extra £70. CA amps are quite 'musical' as well so often better than similarly priced stereo receivers for stereo.
  3. fizl
    fizl
    Apr 21, 2006
    2,164
    Not in London
    +460
    I recently bought the 540R V2 and some mordaunt shorts (definately not floor standers for the size of my room!). I personally think the sound separation for films is very good (but then I was previously on an all in one system), and for music I like the sound alot! It doesn't have any autocalibration, but then I let my ears do the work in its place. It has plenty enough inputs to cover everything I have plugging in to it (including a pc to stream music through on analogue stereo).
    Only had it for a week, and yes I'm probably biased, but I like it :)
    Shaz
