WandererOfDis
Hi all. My first post here because I'm fairly new to the game and feel overwhelmed. First off, my living room is fairly small, I mostly watch movies and play games and own a subwoofer.
I was able to get a good deal on two Dali Spektor 6 speakers which are on their way now. They can still be returned and I'm thinking of doing so in favour of either the Oberon 1 or 3, to be used as fronts.
Because I don't have a particularly large room the speakers would be close to the wall. Dali advises as least 20cm clearance and that would fit, but only just. Considering the ease of placement of bookshelves versus floorstanding, as well as quality tier, should I go for the Oberons instead? If so, which ones would you recommend? The 1 is far better for my wallet and as mentioned I do have a sub.
Additional info: I'm planning, whichever way I'm going with this, to expand to 5.1 with and Oberon Vokal and two Oberon 1 speakers as rears.
Help in this matter would be much appreciated. With these speakers on their way I feel a bit overwhelmed. Thanks.
