Newbie - Connection help please
Discussion in 'Plasma TVs Forum' started by colinho, Nov 2, 2005.
  1. colinho
    colinho
    Hi new to plasma tv but have taken the plunge and would like some advice on how best to connect it all up
    Equipment
    Plasma - Panny TH42PE50
    DVD recorder - Panny DMREH50
    Other - Amstrad Sky +
    Obviously the recorder to the tv will be via component, but what about the sky+ Do i run it through the DVD or connect direct to RBG on the TV ?
    All advice welcome
    Thanks in advance
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    probably best going from the sky tv scart to dvdr and then, as you say, component to screen. This gives best results for recording as the other scart out on sky boxes is not RGB.
  3. colinho
    colinho
    Thanks for the swift reply, does this make the PQ better on screen as well as the recording ?
    And do i have to have the DVD recorder switched on or can it be left in standby like a vcr ?
  4. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    I think it has to be on, the PQ on screen will be about the same
