newbie casio EXilim s2 question
Discussion in 'Photography Forums' started by megabyte, Aug 6, 2003.
  1. megabyte
    megabyte
    Had to buy a camera in a hurry on holidays recently and got this one.
    http://www.megapixel.net/html/issueindex.php?lang=en
    This camera can take 30 seconds roughly of video footage.
    Can anybody tell me how I can run this on my p.c or what soft ware to use.
    The CD that came with it contains nothin for that purpose.
    All I see in it's photo editor is a still from the start of the video sequence and when I try to run it on real player it says I need an update, yet the website has none when I request it.
    Is there a player specifically for this type of video , where and how can I install or get it?
    Many thanks in advance for the help.
    Conor
    *edit* sorry the above link defaults to a homepage, but there is a review of the camera on that site.
  2. jmack
    jmack
    i have this camera and when i want to play a 30 sec clip after uploading to pc i just double click on it and it plays in windows media player, not real player, try right clicking on the file and chose open with and select windows media player,
    hope it works
    i use windows xp
  3. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    Isn't it a standard .avi file that windows mediaplayer will play automatically?
    Else, Quicktime and Realplayer can be set to play the file.
    woody
  4. megabyte
    megabyte
    Thanks a million Guys,media player works a treat :) :clap:
    It's a good job it's so hot and sunny as viewing that bit of video, would've made me want to go back on holiday:D
    Conor
