newbie can you add a music background
Discussion in 'Blu-ray & DVD Players & Recorders' started by pillysblue, Jan 18, 2005.
  1. pillysblue
    pillysblue
    Hello there, can anyone help found this forum and have been reading it for a while now, so i went out and bought a panny e55, i have a lot of vhs that i want to put on dvd. I have some tapes that i would like to put background music onto can i do this straight onto the dvd or will i have to put it onto a dics then into the pc if so any help as to how? Can i do it the same way as i would using my dv camcorder.
  2. pillysblue
    pillysblue
    Please,
  3. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    I don't believe you can do this with any set top recorder.
    You could record to DVD and use the procedure on this forum to edit on a PC... but if you are already able to work with DV and and a PC, I think it easier to use your camcorder as an analogue/digital converter (most can do this), and capture your VHS on your PC as DV. You can then edit, adding music or whatever.
    Mark
