Newbie cable configuration help
Discussion in 'Cables & Switches' started by Cheeky Bob, Jun 7, 2004.
  1. Cheeky Bob
    Cheeky Bob
    Could anyone please help me connect all this up? Mainly the DVD.
    The TV has progressive scan but the DVD doesn't, will it still be beneficial?
    Toshiba 36ZP38 TV
    3 Scart (2 RGB)
    Component Video Output
    Component Video Input
    Digital Optical & Co-axial
    S-Video (Front) want to avoid
    Composite Video
    Daewoo DVG6000D DVD
    1 Scart (Don't think it's RGB)
    S-Video
    Composite Video
    Toshiba ????? VCR (not too bothered about quality)
    2 Scart
    Composite Video
    Sky Digibox (not +)
    Not sure of connections
    Many thanks in advance
  2. Ian J
    Ian J
    Aug 6, 2001
    25,629
    +4,906
    Connect the DVD Player to the TV via the component video connections for the picture and either digital co-axial or optical connection for the sound.
    Connect the Sky box to the TV via a scart cable into one of the RGB enabled sockets. The other scart connection on the Sky box should be made to the VCR and then onwards to a non RGB scart on the TV
  3. Cheeky Bob
    Cheeky Bob
    Thank you, just one more thing, what if the dvd scart is RGB? Is this better than component? and would I still need the digital optical/co-ax?
  4. Ian J
    Ian J
    Aug 6, 2001
    25,629
    +4,906
    Not much in it but the component connection is usually a little better plus the fact it frees up a valuable RGB scart socket on the TV
    Component connections are picture only so you will still need to make a digital connection for the sound. Although scart also carries sound you will still need a digital or optical connection even if connecting via RGB scart if you want the full Dolby Digital sound as the scart will only carry a pro logic signal at best.
  5. Cheeky Bob
    Cheeky Bob
    Thanks again, got it set up and it looks and sounds great for my first 5.1 system. Hate to think what a really good set up is like!
