Newbie - AV recomendations
Unlucky Gumbo
Hi All,
looking to buy an AV soon to start my new home cinema set up, I've not bought speakers yet but was looking to buy the AV first.
I have been recommended a Sony DN1080 but have been looking to see if there is any updated version of this or if a better one is available for a similar price. I am looking to spend around £600 but could push a little more if the right one pops up.
The AV will also need to cater for ATMOS and multiple hdmi inputs
Thanks in advance
Unlucky Gumbo
Thanks for the replies, would you say that the Denon one would be better than the Sony? I really like the sound that the Sony produces as a friend has one but also want to get the best value for money. We will be listening to music through the speakers but mainly will be used for TV, films, game play etc
mushii
Sony has its own sound compared to the Denon or Marantz. You would really need to have a listen to all 3 to decide. The Marantz is probably the most musical of all 3.
dion 6
I've got a Sony str-dn1080 and there is a problem with DTSX it plays atmos from my ceiling speakers but to get DTSX you have to change the settings so I would go for a denon
gibbsy
Both the Denon and Marantz models have Audyssey XT on the entry level models, the Denon X2600. The X3600 has a better version of Audyssey in XT32. Audyssey is superior to the room correction found on the Sony.
There is also the problem with playing DTS:X on the Sony if you go down a 5.1.2 route.
Unlucky Gumbo
I would be only looking to go down the 5.1 route i think however from what i am hearing i am swaying away from the Sony route.
Am i right in thinking that the Denon doesnt offer as much wattage per channel against the sony? and the Denon mentioned above, is that an entry level one or are there better for a similar price?
rccarguy
Denon provide plenty of power, they're one of the better ones.
But they still inflate power figures they're not 180w per channel closer around 70w. But that's much better than Yamaha, which are good with two speakers connected but drop considerably with all speakers connected
Unlucky Gumbo
Unlucky Gumbo
I get that power isnt everything but i also dont want to subsidise it too far and regret not getting a different system.
rccarguy
You need to demo them. You may not like the synergy between them. Also the sub is ok for the price but I'd get something better.
Unlucky Gumbo
thanks Guys - out of stock at both of those.
Have found a place in London that stocks them so have purchased there....next up will be looking to purchase speakers
Jester1066
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
