Question Newbie at work
Discussion in 'AV Receivers & Amplifiers' started by THE BOARS, Jun 19, 2015.
  1. THE BOARS
    THE BOARS
    Nov 25, 2004
    4,219
    83
    +100
    Hi as the headline in a bit new to this
    Basically i have a Yamaha rx-v1065 ,ive just purchased a zappiti 4k media player
    and bought a couple of hdmi 1.5 leads
    the player says it can upscale to 4k [?] can this be done with the above amp or is an upgrade the only option
    Ps i have a 55vt30 so that not an 4k telly
  2. dante01
    dante01
    Mar 5, 2009
    46,638
    +11,249
    The RXV1065 has no 4K video capabilities of any decription so if scaling content up to 4K then it would not be able to be passed through the RXV1065. Also not that there's never been version 1.5 of HDMI and the cables wouldn't be classified or identified using version numbers anyway. Any high speed HDMI cable would be suitable.
    Depending upon the type of 4K content then you'll either need at least a receiver with HDMI version 1.4 or if dealing with UHD 4K content then a new HDMI version 2.0 or 2.0a equipped AV receiver with HDCP 2.2 compliance.
    There's no point scaling anything up to 4K if you've not a 4K TV. You cannot view 4K content without a display that can display 4K.
