Newbie Alert!! Capturing Sky Digital to PC - possible?
Discussion in 'Sky Digital TV Forum' started by dr_mabuse, Mar 31, 2003.
  1. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    I was thinking about buying a Sony PC cos it features a suite of hardware and software called GigaPocket, which is apparently specifically for capturing, editing and burning via the bundled DVD drive.
    Is it possible to capture from Sky Digi (NOT Sky + btw) in this manner? I don't have a VHS so capture from Sky is all I would want it for. Any help given from experts most welcome.
    Or could anyone point me to websites / info that explain all this for a newbie, just in case explanations would be too much info to post here.
    TIA
    dr_mabuse
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Err as long as the harware accepts an RGB or composite video signal i dont see why not
  3. Xeonic
    Xeonic
    As HD said it's possible as long as your capture device accepts a rgb or composite signal. RGB capture cards are rare and expensive, so with a non sky+ box the best bet would be to get a rgb to svideo converter and use that.
    IMHO the best way to cap from sky at the moment would be to forget a PC and use a standalone recorder, like the panasonic e50 or phillips 890 - especially both have rgb input.
    A site like www.vcdhelp.com has lots of info on this stuff :)
  4. GarethRamsay
    GarethRamsay
    Jan 13, 2002
    Many of the TV cards onsale for PCs come with TV recording software which supports scheduling in advance and whatnot. This should suit what you need.
    The only drawback is that without a converter from RGB to S-Video you may only get composite. That said, though, they are very cheap.
  5. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    HD / Xeonic / Gareth
    Thanks for taking the time. :)
    To clear up my no doubt embarassing lack of nouse on this: my Sky Digibox is set to output RGB so as to utilise the RGB input on my TV - and AFAIK this digibox (Pace 2nd Gen) is not one of the rare models able to output S-video.
    Would I have to compromise on this connection path in RGB? I thought that if the cap card was connected to the coaxial out on sky box, it would only output composite anyway? Or is the input to the cap card made some other way?
    Forgive me if I just stated a blindingly obvious question :zonked:
    dr_m
    PS
    At this time I don't want to go to a standalone - I already have a working PC with a burner in it, and I'd just like to add the functionality of recording Sky programmes onto HD then onto DVD. The Sony PC I was considering is apparently equipped with an analogue capture card - this would not achieve what I want?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I think this would work fine but the quality won't be great. As long as you dont mind taht it should be fine.
  7. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    with a capture/tvtuner card, you will be able to just run a coax to the card and tune it in like a TV, which will work fine.
    Better though is to get a scart to 3x phono cable and use a composite connection. This shouldn't interfere with anything else as you should have a second scart output you can use for this.
  8. dr_mabuse
    dr_mabuse
    May 4, 2002
    566
    28
    utopia planitia
    +26
    OK, so I can use the VCR scart output from the Sky Digibox via a Scart to 3 Phono which goes into the cap card - is this the best route to go to maintain decent quality?
    And guess what I'm leading up to - can anyone recommend a good card for capturing digital in this manner? I was looking at the Hauppauge Win-TV Nexus-S but it's difficult to see from the website pic what connections it has.
    Please leave recommendations for different cards to consider - picture quality/resolution is what I'm after.
    TIA
    dr_m
  9. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    I would stay away from Hauppage, the drivers are a bit dodgy.
    The Avermedia cards get good reviews, and you can get them in your local maplins too.
