newbie advice
Discussion in 'Home Cinema Speakers' started by deff, May 21, 2002.
  1. deff
    deff
    Jan 29, 2002
    34
    I am going on an upgrade journey and will ilke some input from all you experts out there. I find that I get better advice on this forum that reading some of the expert mag around!
    I have a dolby digital TV (philips pw329616) with rear speakers which are okish. My latest buy is the rel q400e sub from the Adzman. Does the job very well.
    I have connect the low level directly to the TVs sub out and the hi level to my amp(4 year old HK AV100 with Dolby prologic). Curently I do not use the amp whilest wathing TV or DVD.
    My main speakers are 4yr mission 731 with no centres or rears.
    My question really is how to get setup which is music biased but will also improve my home cinema experience.
    Because of founds I can only upgrade o kit at a time whilst trying to stay away fro buget kit.
    My other kit are dvd:pioneer 545; cd:sony cdpe310;.
    So it is between getting a new amp(s) or speakers. Which one will have the most immediate impact.
    Waiting for your responses
    Deff
  2. jiml
    jiml
    Mar 31, 2002
    Paignton
    An amp would make the biggest difference. If you are happy using the DD processor in your TV, then a straight stereo amp will outperform a DD amp for music at similar prices. For best results feed the front channels of your TV through the amp to get better width and greater dynamics with your DVD's.
