Newbie advice on DVD/HDD purchase - probably Panasonic
Discussion in 'Blu-ray & DVD Players & Recorders' started by smallpaul, Sep 14, 2004.
  1. smallpaul
    smallpaul
    Hi i'm new here so please excuse ignorance...i'm planning to buy a DVDR/HDD combi recorder and spend up to £500 a bit less if possible but maybe more depending on the benefits...Some questions...Panasonic seems to be the most recommended then sony and possibly philips...any opinions welcome
    I mainly want to use it to record from TV like a VCR..maybe also archive old video to DVD...(i use a mac and final cut express to do my own vides so ilink not essential but may be a bonus) i guess a good facility for recording programmes via timer or scheduling would be important
    Can anyone tell me whats the major difference/advantages between the e85 and e95 and e100 or are some of these redundant models? is the only difference between the E85 and E95 the dv in?
    do any of them have a digital tuner. or is there a new model due that i should hang on for?
    Do any/all dvd recorders play 5.1 surround from prerecorded dvds or only stereo? if so which machines will (this is because i have surround speakers and amp from my previous pioneer NV55 system that i'd like to play through, the dvd part has died, hence replacement of dvd)
    Question is what do people recommend and should i take the plunge or wait a few months for an expected feature development (ie digital tuner)
    any help on any of this greatly appreciated either here or via email
    thanks in advance :thumbsup:
  2. Nelviticus
    Nelviticus
    Jun 21, 2003
    473
    Hitchin
    +69
    I can tell you the main differences between the 85 and the 95. The 95 has a 160 GB disk instead of 80 GB, has slots for reading memory cards, and has a quieter fan (apparently). The 100 is a slightly older model than both and has an 80 GB disk. I don't think the 100 can do progressive scan. You can check out their specs here:
    http://www.panasonic.co.uk/dvd-recorders/index.htm
    All DVD recorders will play back the full 5.1 channels for DVD videos, but for some reason the Panasonics only play back DVD-Audio discs in stereo. DVD-Audio doesn't mean "the audio from DVD discs", it's a special type of audio-only disc for high-quality, multi-channel music. There are very few of the discs around though and most people would probably never own one.
    There are currently no DVD recorders that I'm aware of with built-in Freeview decoders. These are on the horizon but I suspect that the first generation ones won't be that good. I would have loved to wait for one but I'd already waited six months and knew that whatever I bought there would always be something better around the corner.
    A word of warning about the Panasonics though - if you want to do timed recordings you have to put them into timer mode. If you just program a timed recording and leave it as it is, it won't record! Quite why Panasonic thought this was a good thing is beyond me. When you do put it into timer mode, it stops passing through sound and video, which is equally daft.
    Apart from that and a few other little quibbles they are great machines, but if I were in your position and I wanted to do a lot of timed recordings I'd look at other manufacturers.
    Regards
    Nelviticus
  3. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    Toshiba rdsx 32 all the mofo way!
  4. JohnC
    JohnC
    Aug 12, 2003
    164
    Central England
    +4
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,877
    Warwick
    +2,791
    The E100 is a redundant model now: the current Panasonic HDD/DVDR lineup is the E85, E95 and E500.
    Panasonic E95 has the following features above and beyond the E85:
    - iLink (DV) Input
    - SD Card slot
    - PC Card Slot
    - JPEG viewer/slideshow
    - 160GB HDD
    Panasonic E500 has the following features above and beyond the E95:
    - MPEG4 recording
    - HDMI Connection
    - DD/DTS Decoding
    - 5.1 DVD-Audio
    - 250GB HDD
    There are currently no HDD/DVDRs with a DVB tuner :( It will be next year before we get anything decent - the first model of which will be the Toshiba RDXS34 (due March).
    The (recommended) Toshiba RDXS32 is well worth looking at - it is loaded with features so read through the link provided above. The Panasonic models offer upto 3hrs full resolution recording though so if PQ is all important consider one of those.
  6. Suzan
    Suzan
    I searched 15+ sites for best price on Panasonic DMRE85 and found...
    DMRE85, Multiregion, +5 discs
    Including VAT and P&P (arrives next day if order placed before 3pm)
    total.......... £434 !!!
    from.... www.digital-point.co.uk
    Pretty impressive
    Still to figure it all out though but there you go :)
    Suzan
  7. JohnC
    JohnC
    Aug 12, 2003
    164
    Central England
    +4
    Toshiba RDXS32 is now going for £379
    John
  8. Rob20
    Rob20
    Jul 3, 2004
    3,188
    +722
    According to HCC, the Pan 500 will come with a 400GB HDD. Though I had seen av land stating that it was 250 GB. Would tend to believe HCC, plus there's already a Jap version with 400GB so it would make sense that the UK also gets a 400GB model. Though it will retail for £1,300!
    There's also a Sony dvd recorder with a digital tuner. Sony 500 or something!? though I can't remember if it has a HDD!? :confused:
  9. steve36
    steve36
    Dec 11, 2002
    965
    Warwickshire
    +33
    Rob,
    Panasonic have constantly released Japanese versions of their DVD-Recorders with larger HD's than UK. Also we had to wait over a year for component output from when USA/Japan received it. So I would be more inclined to believe AVLAND.
    Regarding the sony DVD recorder, from what I've read the digital tuner does not appear to be included in the HD version and if Rasczak says there is'nt one with digital tuner/HD then I believe him!
    I was going to wait for the E500, but I suspect that the price for the extra facilities may put it out of reach.
    Steve.
  10. stuartdcodd
    stuartdcodd
    Sep 16, 2004
    14
    smallpaul
    "i guess a good facility for recording programmes via timer or scheduling would be important"
    Check out the GuidePlus on the Philips HDRW720 - very easy to use!
    Stuart
