Newbie - A bit of help please
Discussion in 'AV Receivers & Amplifiers' started by adamp, Dec 19, 2002.
  1. adamp
    adamp
    Hiya,
    I'm looking to complete my Home Cinema set-up with a budget of about £300.
    I've currently got a Panasonic TX 32DK1 and Pioneer DV-444, also got Sky Digital.
    I've been looking at the Sony HT-DDW740S which I can get for £279. One possible problem is this set-up doesn't have prologic 11 - although I don't know whether that's important.
    Has anyone got any experience with this, or recommend any alternatives for around the same price?
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,077
    notts.
    +63
    hi Adamp
    have a look at the yamaha htib-45 you get a cracking receiver five speakers and a sub it is also easy to upgrade from if you look around on the web you should be able to get one for around £320.
    gonzo
  3. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    Don't buy an amp without DPL II - you'd regret it.
    I waited months for the Sony STR DE585 (same amp as the HT-DDW840S package) to become available. Boy was I glad I waited. It re-creates a very impressive rear surround experience from plain, ordinary Stereo sound.
    Buying an amp now without this would be like buying a tape deck years ago without Dolby Noise Reduction - you wouldn't do it!
  4. adamp
    adamp
    Cheers Guys,
    I have to admit I'd started thinking about the 585 as from what I've read it is a better receiver. I've also been looking at the Pioneer VSX-C100S as it also has DPL II and is slimline to match my player - has anyone got any experience with this or its predecessor the C300S (basically the same but without DPL II).
