newbi Q - what 5.1 bits to add to HS2
Discussion in 'AV Receivers & Amplifiers' started by nsb, Nov 21, 2003.
  1. nsb
    nsb
    I am considering getting a Panasonic HS2 recorder soon, can anyone recommend any particular receiver and speaker set-up to work with it to give surround sound.
    A bit of an open ended question, but that is really my problem, there is so much choice there to start.
    Probably want pro-logic II, probably want to play audio CD/DVD formats. Not using any digital broadcast sources.
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    give us an idea of what money you are talking about..... i know some really fab set ups at thousands of pounds..... but i guess you are looking at hundreds..... but how many of them?
    ad
  3. nsb
    nsb
    As a starter guide price range £300-700.
    Just knowing what to trade off is the problem. If another hundred would really make a difference then I'd just have to save up a bit longer.
