Newbee sky+ question
Discussion in 'Sky Digital TV Forum' started by d3ll, Jan 27, 2005.
  1. d3ll
    d3ll
    Jan 16, 2005
    223
    16
    At the moment we have a aged sony 760 sky box.
    looking to replace that with a sky + box and have the sony in the bedroom, on a second sub.
    Which lnb would I need to be able to run the two digibox's off one dish. Am I correct in thinking that if I installed a quad output lnb, the sky + would use 2 of the outputs and the 3rd to the sony?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Spot on.
    The Quad supplied with SKY+ has (obviously) four independent outputs two of which are used for SKY+ and the other two for any STB you choose to hook up to the LNB.
  3. d3ll
    d3ll
    Jan 16, 2005
    223
    16
    top man, thanks for confirming that :smashin:
