newbee question domino 20h
Discussion in 'Projectors, Screens & Video Processors' started by neil w, Jun 13, 2004.
  1. neil w
    neil w
    Jun 13, 2004
    492
    +18
    hi all
    this is my first post ( of many i hope)
    from my wall to screen position is 12 feet and from my center speaker top to cieling is 59 inches
    can a domino 20h work in my room and what size widescreen will i need with my limited height, all components must fit inside all dimensions( ie 20h inside 12 feet and screen and fixing kit inside 59inch drop
    also whats the going rate to buy 20h and screen ( seen an owl electric 6ft widescreen that looked good)
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Neil,
    Welcome to the avforums and the Sim2 forum in particular.
    In a 12 foot room the max screen size with the 20H would be 60 inches wide allowing for the depth of the projector. The image height would be 33.75 inches.
    The 20H is £3999 and some retailers will have offers on screens supplied with the projector. Look in magazines like Home Cinema Choice for dealers in your area.
    Regards
    Jeff
