Newbee buys wd6bx
Discussion in 'Plasma TVs' started by DIZZ, Jan 10, 2005.
  1. DIZZ
    DIZZ
    Jan 10, 2005
    91
    SURREY
    Yes its done! :) i have orderd a Panasonic th-42pwd6bx from AV sales,
    this is whats coming on wednesday.
    TH-42PWD6bx (plus free Component Video (BNC) svhs, composit, board)
    Desk top stand
    JS RGB to VGA converter
    1m 3 RCA-3BNC component Van Damme Cable
    1m 15pin hd vga-15pin hd vga Van Damme cable
    DVD will go in as component,
    sky via RGB-JS tech box-vga imput,
    av amp will look after the sound.
    If i have read all the posts right, this should be the best conection/supplier and screen options, thanks to everyone here what a minefield it is! (Richer sounds just made it worse) so just one thing, i know to take it out of dynamic mode and cut down the brightness but can anyone help a bit more with the settings? (dos and donts)
  2. garbon
    garbon
    I have also just got this screen, good choice, hear hear for any recomendations on the best settings. I have Sky thru scart and PC on PC in, picture seems fine through the scart. Am waiting for scart switcher from play.com to plug in DVD (it has no component old thosiba but very good) I have reduced brightness contrast anything else?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    get a copy of DVE (digital Video essentials) PAL to set-up properly
  4. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Or better still get it ISF calibrated.
    Piers
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    good point ISF calibration is the way to go............
  6. Supersonic72
    Supersonic72
    Jan 10, 2005
    244
    An odd question, but theres a lot of RicherSounds bashing around...
    Am I missing something?
  7. DIZZ
    DIZZ
    Jan 10, 2005
    91
    SURREY
    I have an old copy of the Avia NSTC set up dvd i know it should be pal but will it be a good starting point?
    and whats ISF (still lots to learn)
    Richer sounds= good prices but advice is patchy
    thanks
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    so is their stock levels and often they havent a clue, useless demo facilities and staff either competely ignore you or try and sell you something else... go there for a PW6 and they will try and sell you a DAEWOO tuner to go with it.......................
  9. midiman
    midiman
    Jan 8, 2005
    320
    London
    I'd go along with that. Popped in there yesterday and the guy didnt seem to know what he was talking about. When I mentioned the Panny he pretty much poo pooed it. Any potential of sale disappeared from that point on
  10. midiman
    midiman
    Jan 8, 2005
    320
    London
    Just a thought but wouldnt a freeview box be a better option then a TV Tuner? After all, RF is subject to ghosting and all sorts. Channel 5 is stilll the pits. At least with freeview you would get a decent picture. Richer Sounds could flog you one for £25 :D
  11. DIZZ
    DIZZ
    Jan 10, 2005
    91
    SURREY
    Yes i did ring them and you are spot on they did recomend the Daewoo tuner
    which i hear is less than good, good job i found this site.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    but because they cant supply terminal boards (wel they sometimes can supply the scart one) they offer you this excellent Daewoo tuner that connects to the VGA input for £99 intead of wasting £150 on a scart board.......which is actually the most useless bit of kit i have seen for a long time..........the fact that with an upscalng amp connected to the VGA input on a PWD6via component gives you an ecellent package escapes them RS are not a quality retailer much of what they sell is cheap items with little performance (when they get decent kit they dont know what to do with it)
  13. blackmanalishi
    blackmanalishi
    garbon,
    Why don't you daisy-chain your DVD through the Sky box rather than shell out for a SCART switcher?
  14. theroux
    theroux
    so how can i get hold of the ISF or DVE PAL. Do they come on dicss?Any idea how much?
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    DVE PAL is a disc £13 from poweruy forum
    ISF is £250 ish a guy comes round and does all the settings for you etc and sets it all up
  16. blackmanalishi
    blackmanalishi
    Send a private message to Piero Milani (on this forum), he'll sort you out with DVE - remember to state PAL.
