New Year "New" Kitchen
Discussion in 'General Chat' started by dUnKle, Dec 27, 2006.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,895
    +2,892
    Help and advice (again) please
    Given up trying to get downstairs rads working - will get new system in summer for next winter.
    Anyway - been in house 3 weeks exactly and it still feels like we are living in someone elses home - we dont have great deal of money (well not now anyway) but would like some cheap ideas on making this house (our first) more like a home.
    First stop is kitchen - its a good size but kinda 1940s meets the 70s. Maybe someone can advise on how we can make it look better. Work tops will have to stay (until we can afford better) and probably units too - it it possible though to paint what we have and add new handles etc ?
    Anyway - here goes with the pics
    The first one is corner near back door near sink. There is an appliance size gap where previous occupants had dishwasher - as its only the two of us we are not going to bother with one - but need something to fill the gap. Any suggestions be welcome - have thought about one of those mobile units that could stay there but wheeled out if extra work space needed. Can these be purchased cheaply ?
    [​IMG]
    Second pic is the corner as you enter kitchen - units can be seen (and obviously need painting or something doing to them) also there is a corner of wall thast empty - can you purchase wall mountable corner units ? something that we could store glasses or bottles on ?
    [​IMG]
    As said - any advice or suggestions welcome - have a week off work and would be good to achieve something
  2. CFC1
    CFC1
    Mar 16, 2006
    15,870
    Europe
    +4,213
    Hi!... It looks like the layout of the kitchen is pretty fixed, so why don't you just change all the doors and handles? It won't cost a fortune and as long as you can measure what you need and can hold a screwdirver, you can do it yourself! B&Q do an extensive range of doors and sizes and prices start at about £18 each. Plus, with the sales on, it's the perfect time to get a bargain. Doing this will make a dramatic change to the kitchen, making it look brand new... Depending on the range of kitchen, you will find that you can get all the add ons/filler pieces that you need, like wine racks etc....
    That's what I would do anyway.
    Good luck!
  3. apul
    apul
    Jan 8, 2003
    689
    Durham
    +19
    I suggest replacing the tiles and the wood panels with new tiles. Cheap enough if you can do the work yourself.
  4. dUnKle
    dUnKle
    Jan 1, 2001
    15,895
    +2,892
    Measured the doors and cupboard fronts - around 9 of each and no more than 2 of each are the same size - would this proove a problem with replacing ?
    If we decide to paint existing what paint do we need ?
  5. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    12,109
    Essex
    +3,035
    I certainly would not paint them. I have friends who have done that and if you don't do it perfectly it will look like your kitchen has scabies.
  6. Lee
    Lee
    Mar 2, 2006
    5,852
    +2,707
    Maybe cover the old appliance gap with a curtain to match whatever colour you do the units. Then store cleaning stuff/bin etc in there.
  7. indianwells
    indianwells
    Jul 14, 2006
    2,092
    116
    Anna Kournikova's Bicycle Seat.
    +1,164
    Whatever you do don't paint them!I did that and it takes ages and looked *****.6 months later I ripped out the whole kitchen and had a new one.:(
  8. dUnKle
    dUnKle
    Jan 1, 2001
    15,895
    +2,892
    Got other half to measure cupboards as well as me just to make sure we had sizes correct
    Cupboard doors are
    600mm by 595mm or
    560mm by 395mm
    Draw fronts seem to be
    395mm by 155mm or
    595mm by 155mm or
    595mm by 180mm
    Checking few online suppliers none of these sizes seem even to be close to what we have :(
  9. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    12,109
    Essex
    +3,035
    There are quite a few on ebay who make to measure, prices don't seem to crazy either, whats your budget?
  10. dUnKle
    dUnKle
    Jan 1, 2001
    15,895
    +2,892
    Would say could afford £500 or so - obviously cheaper the better
  11. CFC1
    CFC1
    Mar 16, 2006
    15,870
    Europe
    +4,213
    I would physically go down to a B&Q superstore. The last time I looked, when I was having my house built last year, they had a really comprehensive range of door sizes.
    Agreed, .....I wouldn't paint the doors... cheap I know, but would look worse in the long run. A specialist spraying company might be an option though, but may end up costing the same as replacing the doors.
    Good luck.
  12. Joe90sDad
    Joe90sDad
    Jan 28, 2006
    585
    28
    Location Location
    +44
    I personally wouldn't touch it. Maybe spray the red trims on the doors or even the beige.
    Save up at least £1000 and just install a whole new kitchen. Yourself, obviously, it's the labour that is the most expensive.
  13. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Try Screwfix.com for replacement doors at pretty good prices :thumbsup:
  14. dUnKle
    dUnKle
    Jan 1, 2001
    15,895
    +2,892
    Think this is option now favored by other half
  15. Paul D
    Paul D
    Dec 27, 2000
    2,799
    Manchester
    +558
    If all the radiators are not working downstairs might mean you central heating pumps is broke/siezed or needs turning up.(ignore all this if it is a combi boiler)
    The rads upstairs work due to gravity circulation etc.
    If some are working downstairs, may mean sludge or dodgy valves.
    If you can get to the pump, try see if you can feel it running.
    If it is not running, try gently tapping it with a hammer!
    You can take the large center screw out, and free the pump with a screwdriver. (turning off the power to the boiler first!)
    But be prepared for some water leakage! (depends on life and age of pump)
    (if that doesn't work, you may need a new pump)
    If it is running, it may be nearing the ends of its life, and you could try turning it up.
    Pumps general have 3 settings, and are normally set to 2.(for a normal size house)
    Switch off the power to the boiler, and switch the dial on the top of the pump to 3. (assuming it is not already set to 3)
    If it doesn't make any diference set it back! (it means you have other problems or the pump is totally knackered etc)
    I'm not a heating engineer but have been training general plumbing as part of my property business, so any advice is given with good intentions only!!!
    :smashin:
