atkins14
So I am waiting to get the keys to my new place and want to get my AV system set up properly. I am looking if anyone can point me in the right direction to get a multi room setup.
My intentions are to get the signal to my bedroom from the living room.
My current living room equipment list as follows:
- Yamaha RX-A1030
- Samsung 55” 4K TV
- PS3
- Sky + Box
- Apple TV
- Dali Zensor 5.1 System
- Media Centre PC
I have been playing around with the HDMI Out 2 onto another monitor which seems to work fine with a direct HDMI cable.
However I intent to get a 4K tv for my bedroom, but I have a feeling the cable length would be over 10m and therefore it wouldn’t be able to transmit 4K over that length.
I have been looking at HDMI over CAT 6, so if anyone has any suggestions or links to a product that would enable 4K media to be transmitted?
I will also run some Zone 2 stereo speakers to the bedroom.
My next issue is getting the remote signal to work from the bedroom. I know there are IR in/out ports on the back of the Yamaha Receiver, does anyone recommend any that is suitable for the Yamaha or is there a better solution I am missing out on?
I understand most those devices can be smartphone app controlled, but I guess the most used controller would be the sky + one.
Any advice or suggestions would be appreciated.
Pete
- Yamaha RX-A1030
- Samsung 55” 4K TV
- PS3
- Sky + Box
- Apple TV
- Media Centre PC
Pete
