New working with old
W
wazza
I have some 6 year old kit which i haven't been able to set up till now; x5 mission 73's, a yamaha dsp a590 and a sony slv e70 video. I'd like to buy a rptv, possibly the tosh 42WT29, but the more I read the more concerned I am about compatibility between my old kit and a rptv. Is that the case and is the toshiba a good buy, I've seen it for £1299?
thanks
wazza
Kevo
Why would it not be 'compatible'?
The speakers and amp don't come into the equation, just your VCR, which is like any other VHS vcr and you'll have noproblems.
To get the most out of the TV though, you're better off with a digital stb and/or DVD player which will give better picture and WS pictures.
W
wazza
Thanks Kevo,
Partly I wasn't sure if the dolby system on my amp was compatible with the recordings on DVD's, when I get a DVD player of course? Also I wasn't sure if I wanted to risk some of the problems some people in the forum seem to encounter with rptv's, colour banding across the screen etc. I don't know whether to get a 36"?
Warren
Kevo
Not sure if the Tosh 42WT29 has built in DD 5.1, even if it does you'd be better off upgrading your amp to a DD/DTS one to get the FULL benefit from DVDs. The difference compared to pro-logic surround is HUGE!
You won't be dissapointed in the Tosh RPs. Make sure it's 100Hz whatever you get. But don't rush into it, take your time and shop around ( I took about 3 months to decide!) Don't forget 'Jan sales' are just around the corner.
Good luck
W
wazza
Thanks again, great idea about waiting for the January sales, I was keen to play with it over xmas, but I can wait if I can save afew quid or upgrade to a better TV.
ta
Wazza
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
