New Wharfedale speakers
Discussion in 'Home Cinema Speakers' started by loadsofleads, Sep 1, 2004.
  1. loadsofleads
    loadsofleads
    The new Diamond 9 series is being launched by Wharfedale at the start of October. I've been intrested in the Evolution series for some time now but I don't want to buy them if a new Evolution series will follow the Diamond 9's.
    Anybody know if Wharfedale is planning to update their Evolution series this year ?
  2. NMyTree
    NMyTree
    Good question, I'd like to know.
    I'm considering the Diamond 9.6 for a third zone in my house. Would be interested in knowing if they have an new Evolution update series in the works.
  3. NMyTree
    NMyTree
    Bump....Bump :lease:
  4. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    729
    43
    +169
    Word has it that Evolution update will not happen this year. More likely for middle of next year.
  5. bobbypunk
    bobbypunk
    Diamond 9s are very poorly finished and built compared to the evo, as soon as they are run in properly i'll give an idea of how they sound.
  6. NMyTree
    NMyTree
    bobbypunk,
    Would you be willing to elaborate on the " very poorly finished and built compared to the evo" comment?
    Is it shoddy workmanship or construction, and cheap materials?
    From what I have read, the Diamiond 9 series is only available in Vinyl laminate finishes. Is this true? Cheap laminates?
    Is the finish and build quality worse than the previous Diamond 8 series?
    Thanks.
  7. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    729
    43
    +169
    Build should be better than the previous all-plastic Diamond 8, but they don't have the real-wood veneer of the more expensive EVOs.
    Diamond 9 has a vinyl wrap on its curves - but unlike D8 it has die-casting for all the bits - trim rings, port tubes, tweeter plates, speaker posts, which is quite unusual sub £200. Depends on how much the vinyl offends you really, because all the other bits are die-cast, not plastic now.
  8. NMyTree
    NMyTree
    Thanks for the reply, Lost Cause.
    I'm not offended by the vinyl laminate finish at all, as long as it's done well.
    I'm considering the Diamond 9.6 and 9.2 for a third zone, a seperate room in the other side of our house; so it's not like those would be my primary system. Just want a hang out room for watching Football, Hockey and listening to some rowdy Rock n Roll, with my friends :D
    In the Living Room, where my primary system is located, I can't have a bunch of friends over for a few drinks (or beers) ; I don't permit rowdy behavior or drinking in the Living Room.
  9. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    729
    43
    +169
    I don't think the 9.2 is coming into the UK, so you're looking at either the 9.1 or 9.4 floorstander. :(
    When I saw them, then I thought the build was OK for a budget vinyl speaker, it certainly didn't ring any alarm bells for me - albeit the veneer clad EVOs are a handsome speaker by anyone's standards.
    Should be fun I would have thought !
  10. NMyTree
    NMyTree
    I'm not in the UK. I'm a Yankee :smashin:
    Actually, I was born in Portugal, and my family moved to the United States when I was 4 years old. But a yankee......nonetheless :D
  11. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    729
    43
    +169
    Weeeeeell, alrighty then !!!
    You should be in luck as those models were intended for the American audience !
  12. NMyTree
    NMyTree
    :D
    They're inexpensive and if they sound as good or better than the Diamond 8 Series; they should serve just fine, for the purpose.
    Afterall, these speakers are likely to take a beating....in that room :laugh: :rotfl:
  13. bobbypunk
    bobbypunk
    They sound reasonable for their price but the finish and level of musical detail is alot lower than the same priced Acoustic energy EVO1 and Montitor Audio B2.
  14. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I'm a real Portuguese :D and I heard the Pacific Evo 10 + 8 + Centre
    Nice looks, nice finish, nice sound character, but they lack plenty of detail compared to MA Silver or AE Elite... :cool:
