New waterproof compact camera
Discussion in 'Photography Forums' started by Dazza Cole, Jun 27, 2015.
  1. Dazza Cole
    Dazza Cole
    Apr 23, 2004
    1,096
    Palm Jumeirah, Dubai
    +21
    Hi all, looking to get a point and click for use on holidays and with the kids swimming, so needs to be waterproof. Doing some research have come up with the following potentials, which seem to have little difference between them. Was wondering if anyone had some practical experience of them and any recommendation / specific pros and cons:
    Panasonic DMC FT5
    Olympus TG-830
    Nikon AW-130
    Canon Powershot D30
    Ease of use and image quality, as well as the speed of capture, are key. All meet the waterproof/toughness requirements
    All suggestions gratefully received :))
  2. shotokan101
    shotokan101
    Jun 16, 2009
    75,862
    33
    Glasgow
    +25,819
  3. snerkler
    snerkler
    Jun 18, 2011
    21,402
    +12,148
    Nikon aw-1 has a larger sensor than most of the others and so should provide better image quality. For ruggedness the Olly tough are tried and tested.
  4. mikeybabes2
    mikeybabes2
    Feb 5, 2011
    2,377
    146
    +2,910
    I've just been through all this as we are going off on a snorkelling holiday at the end of August.
    In the end I went for an Olympus TG-4 as it does raw, has a record of being pretty tough, and has a wide aperture. That will make a big difference, especially if you plan to use it underwater.
    The DP review that Shotokan linked to only covers the TG-3 which has just been replaced by the TG-4, though the only major difference is RAW mode.
    If you are not fussed about RAW, the TG-3 is still available at £ 250 lat Jessops - a saving of £50 over the updated model.
    The Nikon AW-1 might have a bigger sensor, but it is double the price.
    If I hadn't got the TG-4, my second choice would have been the Panasonic.
    I spent ages researching all this - good luck with your choice.
    Mike
  5. Anila Jain
    Anila Jain
    Jan 30, 2014
    112
    UK
    +29
    Me was looking for something like this also.
