New User Please help advice needed
Discussion in 'Desktop & Laptop Computers Forum' started by Ayub, Oct 15, 2003.
  1. Ayub
    Ayub
    Oct 15, 2003
    6,487
    Bradford
    +607
    Hello, i'm new to the forum.
    I have a few questions
    i would like to use my computer as a playing device when i watch films. I have a good colection of films and i want to use my computer to play my cd's too.
    My question is
    if i get a new sound card would that better my sound ( i have a standard 16 bit sound card audio labs came with my computer)
    Also when i play my films does my internal graphic card make a diference ( 128 ddr/hercules)
    the reason i ask the question is i'm going to but a av amp i was thinking of a Yam AX1 as its all singing and dancing i thought i would not need a sound card upgrade.
    second i was thinking of a projector so i wanted to know if getting a better graphic card was needed.
    finally does anyone have any infomation on any sites which show speaker placments.
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,433
    2
    In a secret location with Jennifer Lawrence
    +9,126
    Welcome to the forums.
    I am sure you will find the answers here to all your questions and some you hadn't even thought about!
    The Radeon graphics cards seem to be a more popular choice than Nvidia on this forum for HCPC (home cinema PC) purposes. If you do a search on Radeon there should be a lot of replies come up to help you. (search is at the top right of the page).
    Also a newer sound card should improve the quality. Also does your current soundcard have an sp/dif or other digital output? If not you will definitely need a newer one. Again a search will bring up lots of help for you on this.
    Not sure what your budget is, but the Panasonic projectors get very good mentions on the forum. I have the old model AE-100 myself which I am very pleased with but you can get the newer models from about £750 upwards.
    Hope this helps.
    Greg
  3. Ayub
    Ayub
    Oct 15, 2003
    6,487
    Bradford
    +607
    turn by turn i will be "up grading" the last thing i want to upgrade to is the projector. If i buy it now it will not help my budget. I will in time spend a fair bit on my system. my soundcard is not a good one i wiould like people to make recomendations if possible.
  4. alexs2
    alexs2
    Nov 13, 2002
    13,897
    +1,671
    Welcome.....it's well worth talking to Branxx about PC soundcards,but the M-Audio Revolution is a good card,and the Audiotrak Prodigy192 is also worth a look at the lower price range,especially if used simply as a digital throughput to an external DAC/processor.
  5. Ayub
    Ayub
    Oct 15, 2003
    6,487
    Bradford
    +607
    thanks i will when i see the user online.
