New user - info needed.
Discussion in 'Digital TV & Video Players & Recorders' started by welshpaul, May 19, 2003.
Tags:
  1. welshpaul
    welshpaul
    Mar 2, 2003
    258
    Three questions:-
    1. I am using an Onkyo amp with my Sky + box. Does anyone know where/if i could programme my Sky + remote to control the volume on the amp.
    2. In planner can i watch a previously recorded programme at the same time i am recording a different programme.
    3. My RF aerial picture is perfect when connected into VCR/TV but when it's put via sky + the picture is poor. Anyone help?
    Thanks in anticipation.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I don't know from personal experience if it is possible however I've read of people using the remote to control AV amps, something to do with the SKY+ remote sharing some codes with the one for all type devices I believe.
    Yes you can watch a recorded program while another is being recorded, you can watch the recording program as it's being recorded (Live Pause is example of that).
    There is no need for the SKY+ to be connected to the aerial.
    Connect the SKY+ to the VCR and TV via the scarts and only use the RF output if you are using the TVLink system to feed an extra TV. If you must have a RF loop through then the RF frequency of the SKY+ needs to be adjusted.
    On the remote.....
    Services
    4
    Select
    Then select RF outlets, change the RF channel number, save the setting and then retune the TV's selected RF channel to match.
