New update........how to remove adult channels?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by leedebs, Sep 8, 2005.
  1. leedebs
    leedebs
    Nov 29, 2002
    1,830
    63
    +101
    As title, have a Sky + Pace V2 box that has recently had the software upgrade.
    I heard mention that this update gives the option to remove "adult" channels from the epg.............anyone know how I go about this? :lease:
  2. Heinz
    Heinz
    Aug 4, 2005
    408
    Earle Colne, Colchester
    +15
    I don't think you can actually remove them - just require a PIN to access them.
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    If you do indeed have the latest software then go to the Parental Control menu and selct Adult Channels and then selct ON to remove them from the EPG.
    As indicated in other threads not every digibox has this software.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Indeed, the Parental Controls menu has quite a few new functions. Not only can you remove the adult channels, but you can completely prevent viewing or recording of material rated 12/15/18. Sky are running small trailers every half-hour or so on Sky One & Sky Mix, showing how it works.
