New Type Of Hard Drives?
Discussion in 'Computer Components' started by Garrett, Aug 17, 2002.
  1. Garrett
    Garrett
    Apr 21, 2001
    39,024
    2
    167
    The best thief you’ll never see.
    +6,186
    Anybody know anything about the new format of Hard Drive to come in next year. It is to be serial instead if parallel which is suppose to be quicker. The question will it use the same HD or will the HD to be special serial ones to make use of the system? I also take it as read that to use serial, you will need a new MB to make use of it.
  2. HMHB
    HMHB
    Nov 11, 2001
    26,464
    Nottinghamshire
    +5,087
    The new format is being labeled "serial ATA" at the moment. Current IDE connectors are parallel and so are limited to the speed and bandwidth that can be got out of them - so the switch to serial ATA is inevitable.
    Have a look here for FAQ's:-
    http://www.serialata.org/faqs.html
  3. HMHB
    HMHB
    Nov 11, 2001
    26,464
    Nottinghamshire
    +5,087
    There's more interesting reading here:-
    http://www.pcworld.com/news/article/0,aid,102252,00.asp
    It looks to me as if you'll be able to buy an add in PCI card to provide the serial ATA interface and you may even be able to use old ATA 100 hard disks - but they will be slower
  4. mjn
    mjn
    May 24, 2001
    21,464
    Herts, England
    +9,035
    a parallel connection is quicker than serial connection in PC terms! Due to the way the data is transferred, serial is asynchronous and parallel is synchronous. with a synchronous connection, the data is sent to the device, and then checked to make sure the data that was received was free of errors. Where as synchronous connections, data is just sent down the line to the device. Ever been using windows, printed a document, and windows say the document has printed, but there's nothing come out of the printer?? Well thats because the parallel port does not check for errors, or even if the data go to the printer!!
  5. HMHB
    HMHB
    Nov 11, 2001
    26,464
    Nottinghamshire
    +5,087
    If parallel is quicker than serial how come USB is considerably faster than parallel ??
  6. mjn
    mjn
    May 24, 2001
    21,464
    Herts, England
    +9,035
    because parallel and serial technology is about 20 years old, while usb is very recent, and uses faster chips, ect.
    The serial and parallel connection on your standard PC are being phased out, along with PS/2 mouse and keyboard connections. It will all be USB or USBv2.
  7. HMHB
    HMHB
    Nov 11, 2001
    26,464
    Nottinghamshire
    +5,087
    USB is a serial bus - which is much faster than parallel can ever go - that is why there are no new parallel chipsets etc being produced
  8. The_blue
    The_blue
    Aug 19, 2002
    70
    60 gig running as 40 :eek:
    firmware update anyone ;)
  9. Garrett
    Garrett
    Apr 21, 2001
    39,024
    2
    167
    +6,186
    How then does serial speed compare with RAID?
  10. evildonut
    evildonut
    Jan 21, 2002
    91
    9
    Ecosse
    Nope, it means that the platters in the HD will contain 40 GB max.
    e.g. 180 GB HD = ~3x60GB platters
    so now it'd be 160GB = ~4x40GB platters
    (anybody correct me if I'm wrong)
  11. evildonut
    evildonut
    Jan 21, 2002
    91
    9
    Ecosse
