Question New TV Stand needed
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by chaz, Apr 21, 2016.
  1. chaz
    chaz
    Apr 7, 2003
    3,789
    87
    sussex
    +236
    Hi I am after a new TV table to replace the one I have at the moment which is a tiny bit low in hight. Which is from the floor to the top of the table is 330 mm High, from the top of the TV stand to the Top of the TV is aprox 800mm. The Table is 9oomm long & 500mm wide the Centre Speaker is 500mm long 150mm high and 200mm deep. the table can not be any higher than 370mm high as the TV would then cover part of my Projector screen.Please see Pictures just to add the centre speaker must not be on the same shelf as the TV is so it must have a shelf for the centre speaker plus also the Sky box and Media/ streamer box. I think the max I can go to is about £300.
